Previous Topic: SESSCONFIG CommandNext Topic: WTO Command
SESSLIST Command
The SESSLIST command populates a REXX stem variable with current session attributes for currently loaded sessions selected according to specified criteria. Disabled sessions as specified in the active session definition set are not returned. This command has the following format:
"SESSLIST [SESSTYPE({sesstype|AUTOMATED|PAUSED|CONNECTED|DISCONNECTED|ALL})] [PREFIX(sessname)]"
SESSTYPE
(Optional) Specifies the type of session to be listed. This operand can have one of the following arguments:
sesstype
Lists attributes of sessions in the active session definition set with the console type of sesstype. Possible sesstype names are:
  • ASYNCH
  • DTX
  • ISERIES
  • JES3
  • JES3MCS
  • MCS
  • RCS
  • SYSPLEX
  • TANDEM
  • TANDEMALL
  • VAX
  • VAXALL
  • VM
  • VSE
  • Default
AUTOMATED
Lists attributes of all sessions currently being automated.
PAUSED
Lists attributes of all sessions for which automation is paused.
CONNECTED
Lists attributes of all sessions currently connected to a host.
DISCONNECTED
Lists attributes of all sessions currently not connected to a host.
ALL
Lists attributes of all enabled sessions in the active session definition set.
Default: CONNECTED
PREFIX
(Optional) Specifies the REXX stem variable in which to store the session attributes.This value can be a maximum of 15 characters.
Default: SESSNAME
Output of the command follows:
prefix.DEFINITION_SET
Contains the session definition set name which is currently active in AP desktop
prefix.GLOBAL_PAUSE
Indicates whether global automation pause is currently in effect
prefix.0
Contains the total number of returned sessions
prefix.i
Contains session names (where i is 1 to prefix.0).
prefix.i.attribute
Reports following attributes for each session, where i is 1 to prefix.0 and attribute is one of the following keywords:
AUTOMATED
Indicates the automation status:
  • YES: session is currently being automated
  • PAUSED: automation is temporarily paused
  • NO: session is non-automated
CONNECTED
Indicates the connection status:
  • YES: session is currently connected
  • NO: session is currently not connected
CONSOLE_TYPE
Indicates the console type (Default, ASYNCH, MCS, TANDEMALL, DTX, RCS, VAX, JES3, SYSPLEX, VAXALL, JES3MCS, TANDEM, VM, VSE, ISERIES)
DEVICE_NAME
Indicates the LU name or Device name (applicable only for TN3270, TN5250 )
DEVICE_TYPE
Indicates the communication device or protocol used to connect the session
  • COMn: Serial communication port n (COM1, COM2, ...)
  • MEMORY: Session that uses memory as communication device
  • ETC: Session is controlled by the Event Traffic Controller
  • VIO: Windows command prompt session
  • TELNET, SSH, TN3270, TN5250: Session is connected to a remote host using this protocol
HOST_NAME
Indicates the host name (applicable only for TELNET, SSH, TN3270, or TN5250)
HOST_PORT
Indicates the port (applicable only for TELNET, SSH, TN3270, or TN5250)
MENU
Indicates a custom menu name or Default
SESSION_NAME
Indicates the name of the session
SYSTEM_NAME
Indicates the system name
TERMINAL
Indicates the terminal type (3278, 3278_2, 3278_3, 3278_4, 3278_5, 3279, 3279_2, 3279_3, 3279_4, 3279_5, 3477, 5292, 6530, ASYNCH, AXC, VIO, VIO43, VIO50, VT52, VT100, VT320, VT420)
TITLE
Indicates the title
If an attribute is not applicable for particular session, the attribute value contains the string "N/A".
