The notification server component resides on a workstation of your choice. If you install more than one notification server, each one must reside on a separate workstation. The VOX command environment component can reside on a notification server workstation or on any network-connected workstation from which REXX-based VOX commands originate. The voice word library resides on a notification server workstation.
The following illustration shows how the Notification components work together:
Copyright © 2011 CA.
