To enhance the usefulness of REXX-and CA Automation Point connectivity to other hardware and software, CA Automation Point allows lets your REXX programs access special command environments, including the following:
Used to communicate within the CA Automation Point environment and the console windows. This is the default environment for issuing command processors specific to CA Automation Point.
Used to execute operating system commands.
Lets you to store status values while CA Automation Point is running in order to maintain consistent data across restarts.
Involves interaction with the CA OPS/MVS interface.
Used for queuing information between processes and remote systems. It can be used locally and over a network.
Involves interaction with CA NSM using the CA NSM WorldView and Event Management interfaces.
Involves inbound and outbound voice processing, paging, and email.
Note: For information about accessing various command environments from REXX programs, see the Reference Guide.
Copyright © 2011 CA.
