Introduction › Overview › Event Monitoring and Automation
In the areas of event monitoring and automation, you can do the following:
- Manage events from multiple platforms and devices
- Consolidate management of all host consoles from different systems, platforms, and devices into a central point
- Increase system availability by automating systems management and problem detection, notification, and resolution
- Initiate and automate the entire IPL/IML process.
- Simultaneously view and automate the following:
- z/OS MCS consoles
- JES3 console sessions
- VTAM and CA Remote Console sessions
- VM and VSE console sessions
- TPF sessions
- iSeries (AS/S400) sessions
- Telnet, SSH, UNIX, LINUX, OpenVMS sessions
- Remotely view managed secured sessions from a Windows workstation through the Remote Viewer and the Web Message Viewer
- Capture messages and events from the Windows Event log
- Handle automation requirements using rules. Rules can be message-, time-, or command-based
- Handle the management of complex automation applications using REXX programming
- Export a message during rules processing to a customer-written function using a rules keyword
- Enable session-level and user-level security by leveraging Windows file security
Copyright © 2011 CA.
