The UNICMD keyword tells the CA NSM Event Manager, which resides on the specified host, to execute the supplied command.
This keyword has the following format:
UNICMD(HOST(HostName) COMMAND(CommandString))
Specifies the name of the host on which the CA NSM Event Manager resides.
Specifies the command to be executed by the CA NSM Event Manager.
Example:
The following example copies a file from the temporary directory to an application directory on the remote Windows host named UNIHOSTA:
UNICMD(HOST(UNIHOSTA) COMMAND(COPY C:\TEMP\YOURDATA.DAT
C:\YOURAPP\YOURDATA.DAT))
