Previous Topic: MSGID Keyword
Next Topic: WHEN Keyword
TIME Keyword
The TIME keyword specifies the time when a rule can execute. The time you specify cannot be a status variable value.
This keyword has the following format:
TIME(hh:mm)
hh:mm
Specifies the time when a rule is to execute in hours (hh) and minutes (mm) on a 24-hour clock.
Example:
If your site routinely IPLs the mainframe at 7:00 p.m., write the following time rule to notify TSO users ten minutes before the IPL occurs:
TIME(18:50),
OSCMD(('SEND “WARNING; IPL IN 10 MINUTES” '),SESSION(SYS_A))
