The following are Notification Manager methods that are called by NMFIND.
Provides a means for NMFIND to contact a person or group using the local e-mail system.
Provides a front-end to the NMMAIL program. NMFIND uses this command to contact a person or group by initiating an alphanumeric page through the e-mail system.
Provides a means for NMFIND to contact people through the local area network (LAN) by issuing a NET SEND command.
Provides a means for NMFIND to contact someone through a TAP alphanumeric or numeric pager.
Provides a means for NMFIND to contact someone through a 2-way messaging device.
The NMSPEAK program is used by NMFIND to contact a person or group through speech using the TCP/IP network.
Provides a means for NMFIND to contact someone through a TAP alphanumeric or numeric pager. It differs from NMPAGE in that the REXX code talks directly to the modem instead of using the ADDRESS VOX PAGE command to perform the page.
NMTAP supports the batching of pages (that is, sending multiple pages to a paging service with a single phone call). NMTAP is designed so that you can easily modify it to support a different protocol than TAP. For more information, see the NMTAP.TXT file in the Distrib directory.
Provides a means for NMFIND to contact someone through a voice card and, optionally, ask them to make a selection from a set of options.
