Keyboard parameters define keystrokes in the keyboard parameter file. The following table lists the CA Automation Point parameters you need to define when specifying your keyboard parameter file.
Identifies the name of the operation.
Indicates the electronic location of the key.
Specifies the type of window on which this operation applies.
