Previous Topic: Script Keyword Descriptions
Next Topic: ERROR Keyword
ENDSEARCH Keyword
The ENDSEARCH keyword terminates a search initiated by a SEARCH keyword.
This keyword has the following format:
ENDSEARCH
Example:
When an MCS console is active and operating correctly, it displays a message similar to one of these:
IEE152 ENTER CANCEL D C,K
IEE612I CN=05 DEVNUM=B4C SYS=S028 CMDSYS=S028
Suppose that your script contains these statements:
ERROR=IGNORE
SEARCH=(IEE152I)
  KEY=(K S,DEL=N,SEG=20,MFORM=(T,J)@E)
ENDSEARCH
SEARCH=(IEE612I)
ENDSEARCH
The statements take the following actions:
  1. The first SEARCH statement tells CA Automation Point to search for the IEE152I message.
  2. If the first SEARCH statement finds message IEE152I, the KEY statement executes, putting the console in nondelete mode, setting the segment length to 20 lines, and so on; if the SEARCH operation does not locate the IEE152I string, the ERROR statement tells CA Automation Point to continue processing.
  3. The ENDSEARCH statement terminates the first search operation.
  4. CA Automation Point executes the second SEARCH operation (for the IEE612I message) in the same way.
