The DELETE command deletes all elements in the specified queue and releases the memory allocated for the queue.
ADDRESS PPQ 'DELETE QUEUE(qname) [WAIT({NO|YES|waittime})]'
Specifies the 1- to 16-character name of the queue (qname). The queue name can contain alphanumeric characters and any of these special characters: ! @ # $ _
The queue name cannot contain blanks.
(Optional) Specifies what the command does if it cannot execute immediately. For example, the queue may be in use or locked by another REXX program. Valid WAIT values are:
Returns a nonzero return code (RC) value immediately. (For information about what happens when a command does not execute successfully, see the chapter on using program-to-program queues in the Administrator Guide.
Waits indefinitely while blocking the current REXX program until the queue becomes available.
Specifies the number of seconds to wait (up to 100000) while blocking the current REXX program. Fractional values (such as 1.5) are valid.
Default: NO
Usage Notes:
The following restrictions apply to the DELETE command:
