Previous Topic: DELVAR Command
Next Topic: GETREXXL Command
GETMSGI Command
The GETMSGI command fetches the internal pointer to an action message and the actual message text.
"GETMSGI"
Usage Notes:
When you invoke the GETMSGI command, it populates the following REXX variables as shown:
REXX Variable
Contents After Invoking GETMSGI
DOMID.0
The number of messages in the CA Automation Point action message recall list. This variable contains a value from 0 through 100.
DOMID.n
The internal pointer to message number n in the action message recall list.
DOMID_MSG.n
The text for action message number n in the action message recall list.
After invoking the GETMSGI command, you can use the DOM command to delete specific action messages from the CA Automation Point action message recall list.
Example:
Suppose that you want to delete all of the action messages in the CA Automation Point action message recall list every night at midnight. You could set up a time rule to invoke a REXX program like the following one:
"GETMSGI"
DO CNT=1 TO DOMID.0 BY 1
  INTERPRET 'CUR_DOMID=DOMID.'CNT
  "DOM DOMID(&CUR_DOMID)"
END
