The following legend helps you read the syntax diagrams provided for each statement and command:
Identifies abbreviations. The uppercase letters are the minimum abbreviation; lowercase letters are optional.
Identifies a value that you must supply.
Identifies optional operands.
Indicate a list of mutually exclusive (meaning you must specify only one) constants separated by a vertical bar or bars {|}.
Indicates the default value.
Note: Positional parameters, keywords, and operands are indicated by indented text in the syntax diagrams.
