Previous Topic: NMVOICE Method
Next Topic: NMVOICE Parameter Descriptions
NMVOICE Method Parameters
Define the following parameters for any method you create that invokes NMVOICE. If a parameter is marked as required, you must define it as a parameter for the method. If a parameter is not required, you do not need to define it in the database. If you do not define the parameter, the default value is to be used whenever the method is invoked.
Note: You cannot set a value for a parameter at the entity or time-block level (that is, override the default value) if you do not define the parameter at the method level.
Parameter
Required
CallRetry
No
CallRings
No
CallWait
No
ChannelWait
No
Debug
No
Greeting
No
LeaveMessage
No
PassOnItemNumber
No
Phone
Yes
System
No
UsePIN
No
Wordlib
No
