Previous Topic: NMSPEAK Parameter Descriptions
Next Topic: NMTAP Parameter Descriptions
NMTAP Method
The NMTAP program provides a means for NMFIND to contact someone with a TAP alphanumeric or numeric pager. It differs from NMPAGE in that the REXX code talks directly to the modem instead of using the ADDRESS VOX PAGE command to perform the page. NMTAP supports the batching of pages (that is, sending multiple pages to a paging service with a single phone call). NMTAP is designed so you can easily modify it to support a different protocol than TAP. For more information, see the nmtap.txt file in the Distrib directory.
NMTAP only communicates with TAP alphanumeric pager services. Therefore, you can only use NMTAP to page a numeric pager if that pager is reachable with an alphanumeric pager service. You cannot call NMTAP directly; rather, you must install it as the invocation string for a method in your Notification Manager database and use NMFIND to invoke it.
Specify the following items when defining a method that uses NMTAP:
As mentioned previously, NMTAP supports the TELL parameter of NMFIND, but it does not support the ASK parameter of NMFIND (it can be used only as a TELL method). The text sent to a numeric pager is the line on which to call in and the item number. The text sent to an alphanumeric pager is the line on which to call in, the item number, and some or all the text of the TELL message.
Define the following parameters below for any method that uses NMTAP as its invocation string. If a parameter is marked as required, you must define it as a parameter for the method. If a parameter is not required, you do not need to define it in the database. If you do not define the parameter, the default value is used whenever the method is invoked. Remember, you cannot set a value for a parameter at the entity or time-block level (that is, override the default value) if you do not define the parameter at the method level.
The following is a list of method parameters that are to be stored in the Notification Manager database for each NMTAP method definition:
Parameter
Required
AnswerWait
No
BatchPage
No
BatchWait
No
BaudRate
No
Comport
No
DataBits
No
Debug
No
Greeting
No
MaxMsgLen
No
ModeCmd
No
ModemInitString
No
ModeString
No
NMfindWait
No
Numeric
No
PageRetry
No
PagerID
Yes
PagerPW
No
PageWait
No
Parity
No
Phone
Yes
StopBits
No
TellExact
No
