Previous Topic: OSFTSO Command
Next Topic: WTO Command
VER Command
The VER command provides the version number of the CA Automation Point interface to CA OPS/MVS on your workstation.
ADDRESS OPS 'VER [CMDRESP(destination)] [PREFIX(newvarname)]'
CMDRESP
(Optional) Directs return information to a specific destination. For a description of valid destination values, see ADDRESS OPS Return Information in this chapter.
Default: REXX
PREFIX
(Optional) Directs return information to a stem variable name (newvarname) other than the default. For more information, see the section ADDRESS OPS Return Information.
Note: The PREFIX operand is valid only if the destination of the return information is REXX.
Default: OPS.VER
Return Information:
The VER command returns one line of information containing four fields. The fields contain the following information:
Field
Description
1
The name of the API (for example, OPS Rexx C API)
2
The version number (for example, 11.3.0.0 Rev=99999)
3
The Build date of the current CA OPS/MVS service in mmm dd yyyy format (for example, Jul 05 2010)
The following is an example of a return information line:
OPS Rexx C API 11.3.0.0 Rev=99999 Jul 05 2010
For more information, see ADDRESS OPS Return Information in this chapter.
