Previous Topic: ADDRESS OPS Return Information
Next Topic: The OPS.ERROR Variable
The RC Variable
RC is the REXX variable that contains the return codes from the ADDRESS OPS environment. RC is set by every command and should be programmatically checked for acceptable results (usually a zero value) after each command executes.
