Previous Topic: GETTAPIDEVICELIST Command
Next Topic: SETMSGSTREAM Command
SETENGINE Command
The SETENGINE command allows you to modify various settings that are directly associated with the notification server.
ADDRESS VOX "SETENGINE ENGINESETTING(AUTORESET) VAR(var.) [SYSTEM(sysname)]"
ENGINESETTING
Specifies the ENGINESETTING operand enables you to change the default autoreset period to a setting other than five minutes.
VAR
A stem variable name (var.) that you assign containing the autoreset value. The specified stem variable must contain the following information:
varname.0
Must be 1
varname.1
The value you wish to set for the ENGINESETTING value
SYSTEM
(Optional) Specifies the name of the system to which you want to direct the command.
The sysname value can contain up to eight alphanumeric characters.
Default: The local system name
Return Information:
After the SETENGINE command executes, it sets the special REXX return code variable RC.
Example:
The following REXX code illustrates how to use the SETENGINE command to set the autoreset to three minutes:
 value.0 = 1
 value.1 = 3  /* value of 3 minutes for auto-reset */
   address VOX "SETENGINE ENGINESETTING(AUTORESET)     VAR(VALUE.)"
