Previous Topic: STOP Command
Next Topic: WINK Command
VERIFYUSER Command
The VERIFYUSER command verifies that the remote party's user ID and password are valid.
ADDRESS VOX "VERIFYUSER USERID(userid) PIN(pin) [SYSTEM(sysname)]"
USERID
Specifies the remote party's user identification number. The userid value must contain between four and eight tone digits (valid values are 0000 through 99999999). Valid characters are: 0 1 2 3 4 5 6 7 8 9
PIN
Specifies the remote party's personal identification number (pin) password. The pin value must contain between four and eight tone digits (valid values are 0000 through 99999999). Valid characters are: 0 1 2 3 4 5 6 7 8 9
SYSTEM
(Optional) Specifies the name of the system that is running the notification server to which you want to direct the command.
The sysname value can contain up to eight alphanumeric characters.
Default: The local system name
Return Information:
After the VERIFYUSER command executes, it sets the special REXX return code variable RC.
Note: When assigning user IDs and PINs, we recommend that you choose tone digits that spell a name or meaningful code on the telephone keypad. For example, if a user ID is SAMJONES, the remote party with that user ID would enter these corresponding tone digits: 72656637. It is usually much easier for a remote user to remember a mnemonic string (such as a name) than it is to remember an arbitrary string of numeric digits.
Example:
The following REXX code illustrates how to use the VERIFYUSER command to verify a caller's user ID and PIN:
/* Get exclusive access to a specific voice channel. */
address vox 'getchannel channelnum(1) prefix(handle)'
/* Get the caller's user ID. */
address vox 'playgetdigits channel('handle') file(entruid.vox) count(8) singlestring(yes) prefix(userid)'
/* Get the caller's personal identification number (PIN). */
address vox 'playgetdigits channel('handle') file(entrpin.vox) count(8) singlestring(yes) prefix(pin)'
/* Verify that the remote user has entered a */
/* valid user-id/pin combination.            */
address vox 'verifyuser userid('userid') pin('pin')'
if RC == 0 then
do
   /* Processing for valid remote user. */
end
/* Release the voice channel. */
address vox 'releasechannel('handle')'
