Previous Topic: NMILISTITEMS Command
Next Topic: Notification Commands
NMIMPORT Command
The NMIMPORT command imports an exported copy of a Notification Manager database.
Important: This command destroys all existing data in the database before importing new data.
ADDRESS VOX "NMIMPORT PATH(path)"
PATH
Specifies the name of the path from which the exported database is retrieved.
Return Information:
After the NMIMPORT command executes, it sets the special REXX return code variable RC.
Usage Notes:
Example:
The following example imports a copy of an exported database that resides in the G:\TEMP_EXP directory:
ADDRESS VOX "NMIMPORT PATH(G:\TEMP_EXP)"
