Previous Topic: SET Command
Next Topic: SETLP Command
SETL Command
The SETL command assigns a literal value, which can contain blanks, to a single volatile status or GLV variable.
ADDRESS GLV '[SELECT vargroup] SETL varname value'
SELECT
(Optional) Specifies the name of a variable group (vargroup) to which the specified variable (varname) belongs.
For more information, see the description of the SELECT command.
varname
Specifies the name of a volatile status or GLV variable.
Note: If you assign a value to a volatile variable, and a nonvolatile variable of the same name already exists, the nonvolatile variable will be erased.
value
Specifies the value to assign to the variable specified by varname. Valid values are literal strings. The value can contain blanks.
Example:
The following REXX statement assigns a literal value to the volatile variable MESSAGE:
ADDRESS GLV 'SETL MESSAGE This is a sentence in one variable'
