Previous Topic: LOCK Command
Next Topic: UNLOCK Command
READ Command
The READ command reads one or more items from a specified queue.
ADDRESS PPQ 'READ QUEUE(qname) [COUNT(numitems)]
                               [CMDRESP(destination)]
                               [ITEMNUM(FIRST|LAST|itemnum)]
                               [PREFIX(newvarname)]
                               [REMOVE(YES|NO)]
                               [WAIT(NO|YES|waittime)]'
QUEUE
Specifies the 1- to 16-character name of the queue (qname). The queue name can contain alphanumeric characters and any of these special characters: ! @ # $ _
The queue name cannot contain blanks.
CMDRESP
(Optional) Directs return information, if any, to a specific destination. For a list of valid destination values, see the section Change the Default Return Destination with CMDRESP.
Default: REXX
COUNT
(Optional) Specifies the number of items (numitems) to read from the queue.
Default: 1
ITEMNUM
(Optional) Specifies the starting item to read from the queue. The starting item that you specify must exist; the READ command cannot wait for an item that does not yet exist. Valid ITEMNUM values are:
FIRST
Starts the read operation from the first item in the queue.
LAST
Starts the read operation from the last item in the queue.
itemnum
Starts the read operation from an item number that you specify. (A value of 1 is the same as a value of FIRST.)
Default: FIRST
PREFIX
(Optional) Directs return information to a stem variable name (newvarname) other than the default. For more information, see ADDRESS PPQ Return Information.
Note: The PREFIX operand is only valid if REXX is the destination of the return information.
Default: PPQ.READ
REMOVE
(Optional) Specifies whether the read operation is destructive or nondestructive (that is, whether the READ command removes an item from the queue after it has read the item). Valid values are:
YES
Removes the item from the queue after reading it.
NO
Does not remove the item from the queue after reading it.
Default: YES
WAIT
(Optional) Specifies what the command does if it cannot execute immediately. For example, the queue may be in use or locked by another REXX program. Valid WAIT values are:
NO
Returns a nonzero return code (RC) value immediately. For information about what happens when a command does not execute successfully, see the chapter on using program-to-program queues in the Administrator Guide.
YES
Waits indefinitely while blocking the current REXX program until the queue becomes available and is not empty.
waittime
Specifies the number of seconds to wait (up to 100000) for the queue to become available while blocking the current REXX program. Fractional values (such as 1.5) are valid.
Default: NO
Usage Notes:
