Previous Topic: The PPQ.ERROR Variable
Next Topic: Changing the Default Variable with PREFIX
Additional Return Information
The following PPQ commands, if executed successfully, return additional information beyond a return code (RC) value:
Return information is stored in the special variable PPQ.ppqcommand. (The ppqcommand portion of the stem variable represents the name of the PPQ command.)
The PPQ.ppqcommand.0 variable contains the number of lines of information returned (that is, the number of elements in the PPQ.ppqcommand variable). The variables PPQ.ppqcommand.1 through PPQ.ppqcommand.n each contain a line of information. (The n value represents the last line of return information.)
Note: The PPQ.ppqcommand variable contains the same value stored in the PPQ.ppqcommand.1 variable (that is, the first, and sometimes only, return information line).
