Change properties of a specific message
None
Message in schema Message.xsd
Currently the PUT method only allows changing the ActionMessage element value from yes to no, which removes the message from the AP action message window. Any other changes that are contained in the input document are ignored.
Supply a user ID and password in the HTTP Basic Authentication format. The user ID must be a user account with the AP Remote Viewer FULL privilege on the session that is the target of this HTTP method.
Successful result = 200 = Ok
None
