Previous Topic: OPTIONS sessions/<sessionName>/messages
Next Topic: URI https://localhost:8443/apwebsvc/sessions/<sessionName>/messages/ <messageId>
POST sessions/<sessionName>/messages
Submit a message into the AP rules engine treating the message as if it came from the associated AP session.
Query Options
None
Request Document
Message in schema Message.xsd
The request contains properties of the message, for example, message text, application name, host name, category, and severity. The ProcessTime property is automatically populated by CA Automation Point and can be omitted in the request document.
HTTP Request Headers
Authorization
Supply a user ID and password in the HTTP Basic Authentication format. The user ID must be a user account with the AP Remote Viewer FULL privilege on the session that is the target of this HTTP method.
HTTP Response Headers
Status
Successful result = 201 = Created
Location
Contains the URI to the newly created message
Successful Reply Document
MessageReply in schema Message.xsd
The reply contains the URI which identifies the created message. That URI is also returned in the HTTP Location header.
