Send a notification.
None
NotificationRequest in schema NotificationRequest.xsd
The request contains characteristics of the notification, such as who is notified and what is NM to tell that person.
Supply a user ID and password in the HTTP Basic Authentication format. The user ID must be an NM Login with the Notify All contacts privilege on the AP server that is the target of this HTTP method.
Successful result = 202 = Accepted
Contains the URI to the newly created notification.
NotificationRequestReply in schema NotificationRequest.xsd
The reply contains the URI which identifies the created notification. That URI is also returned in the HTTP Location header.
