Previous Topic: OPTIONS intsessions/<intsessName>/messages/<messageID>
Next Topic: Notification URIs
PUT intsessions/<intsessName>/messages/<messageID>
Change properties of a specific message
Query Options
None
Request Document
Message in schema Message.xsd
Currently the PUT method only allows changing the ActionMessage element value from yes to no, which removes the message from the AP action message window. Any other changes that are contained in the input document are ignored.
HTTP Request Headers
Authorization
Supply a user ID and password in the HTTP Basic Authentication format. The user ID must be a user account with the AP Remote Viewer FULL privilege on the internal session that is the target of this HTTP method.
HTTP Response Headers
Status
Successful result = 200 = Ok
Successful Reply Document
None
