Submit a message into the AP rules engine treating the message as if it came from the associated AP internal session.
None
Message in schema Message.xsd
The request contains properties of the message. For example, message text, application name, host name, category, severity, and so on. The ProcessTime property is automatically populated by CA Automation Point and can be omitted in the request document.
Supply a user ID and password in the HTTP Basic Authentication format. The user ID must be a user account with the AP Remote Viewer FULL privilege on the internal session that is the target of this HTTP method.
Successful result = 201 = Created
Contains the URI to the newly created message.
MessageReply in schema Message.xsd
The reply contains the URI which identifies the created message. That URI is also returned in the HTTP Location header.
