Previous Topic: NMIGETITEM Command
Next Topic: NMILISTCALLERS Command
NMILISTANSWERS Command
This command lists the answers that are specified using the NMFIND ASK parameter (if any) for the specified notification request.
ADDRESS VOX "NMILISTANSWERS ITEM(item) [CMDRESP(destination)] [PREFIX(varname)]"
ITEM
Specifies the item number.
CMDRESP
(Optional) Directs return information, if any, to a specific destination. For a list of valid destination values, see ADDRESS VOX Return Information.
Default: REXX
PREFIX
(Optional) Specifies the name of the REXX stem variable (other than the default name) that contains the return information for the command.
For information about changing the default variable name, see ADDRESS VOX Return Information.
Default: VOX.NMILISTANSWERS
Usage Note:
For more information on this command, see the sample REXX program listanswers.rex in the CA Automation Point installation folder \sample\nm.
Return Information:
After the NMILISTANSWERS command executes, it sets the special REXX return code variable RC.
Example:
The following example retrieves the list of all answers that are specified for notification request item number 1234:
ADDRESS VOX “NMILISTANSWERS ITEM(1234)”
