Previous Topic: LISTTIME Command
Next Topic: NMEXPORT Command
NMDBMERGE Command
The NMDBMERGE command merges a previously exported copy of a database into the current Notification Manager database. Names (entity name, method name, time block name, and so on) are used to check for duplicate data. If a duplicate is found, the original data is replaced with the imported data. Otherwise, a new entry is created in the database. The NMDBMERGE command merges existing data with imported data.
ADDRESS VOX "NMDBMERGE PATH(path)"
PATH
Specifies the name of the path from which the exported database is retrieved.
Return Information:
After the NMDBMERGE command executes, it sets the special REXX return code variable RC.
Usage Notes:
Example:
The following example imports a copy of an exported database that resides in the G:\TEMP_EXP directory:
ADDRESS VOX "NMDBMERGE PATH(G:\TEMP_EXP)"
