The following are components of the TPF REXX Interface
TPFCON.REX is the main module that manages the interface. It processes all system- and user-initiated messages through the CA Automation Point rules engine. This file resides in the installDir\Distrib directory.
TPFREAD.REX is the REXX program that parses the TPF message into a REXX stem variable called TPFWD. This variable gives you access to every word in a message to act on. This file resides in the installDir\Distrib directory.
The file axcrules.rul contains sample rules to run against the TPF session. This file resides in the installDir\Distrib directory.
