The following session state script configures an MCS console session for use by CA Automation Point.
*------------------------------------------------------------------------------* * FILENAME: MCS.SCR * * * * USE: This script configures an MCS console for control by Automation * * Point by issuing 'K' (control) commands. To execute RULES * * against MCS console messages, and to send those messages to the * * Automation Window, Automation Point requires the console to be in * * non-delete mode, with time and job stamps. Automation will not * * commence until the console is in this mode. * * * * UPDATED: 7-JUL-94 * * * * NOTES: One characteristic of MCS consoles is that if you enter an invalid * * or out-of-sequence 'K' command, the console will not accept any * * new commands until you enter the command correctly or press the * * PA2 key to reset. * * * *------------------------------------------------------------------------------*
ERROR=IGNORE * If search fails, proceed to next search *------------------------------------------------------------------------------* * Put the console in non-delete mode, 20 lines/segment, etc. * * * * Note! The number of lines per segment will vary from console to console. * * Make sure that that the number used below matches your console. * *------------------------------------------------------------------------------* SEARCH=(IEE151I) * Delete request inconsistent KEY=(@y) WAIT=1 ENDSEARCH
* The following message appears on the status line of a healthy pre MVS/SP 4.1 *
* MCS console. If found, set the console characteristics for AP's use. *
* IEE152I ENTER CANCEL D C,K *
* If we attempt to set it to roll more lines than it has, the status line is: *
* IEE156I K INVALID OPERAND -20 *
SEARCH=(IEE152I) * Look for 'IEE152I' - if found, reconfigure console
KEY=(k s,del=n,seg=39,con=n,mform=(t,j)@E)
WAIT=1 * Wait 1 second for the command to be accepted
SEARCH=(IEE156I) * Look for 'IEE156I' - if found, try again
KEY=(@y) * (@y=PA2)
KEY=(k s,del=n,seg=20,con=n,mform=(t,j)@E)
KEY=(@y) * (@y=PA2)
KEY=(k s,del=n,seg=19,con=n,mform=(t,j)@E)
ENDSEARCH * End of commands to perform if 'IEE156I' is found
ENDSEARCH * End of commands to perform if 'IEE152I' is found
*------------------------------------------------------------------------------* * If the IEE152I is still there, we want to delete the display area, if one is * * defined, because display areas cause problems for rules processing. * *------------------------------------------------------------------------------* SEARCH=(IEE152I) * Look for 'IEE152I' - if found, reconfigure console KEY=(k e,d@E) * Clear the display area (@E=ENTER) WAIT=1 * Wait 1 second for the command to be accepted
*------------------------------------------------------------------------------* * If the console didn't have a display area, the following error message * * will have been displayed in the console status line: * * * * IEE151I DELETE REQUEST INCONSISTENT-NO DISPLAY ON SCREEN ENTER CANCEL * * * * Just in case that happened, send a PA2 using the mnemonic '@y' * *------------------------------------------------------------------------------* KEY=(@y) * (@y=PA2) WAIT=1 * Wait 1 second for the command to be accepted KEY=(k a,none@E) * Delete the area so we won't get more area displays WAIT=1 * Wait 1 second for the command to be accepted KEY=(axc here@E) * Tell CA-OPS/MVS that AP is active at this console WAIT=1 * Wait 1 second for the command to be accepted ENDSEARCH * End of commands to perform if 'IEE152I' is found
* The following message appears on the status line of a healthy MVS/SP 4.1 or *
* above (including all z/OS versions) MCS console. If found, set the console *
* characteristics for AP's use. *
* IEE612I CN=02 DEVNUM=60D SYS=S032 CMDSYS=S032 *
SEARCH=(IEE612I) * Look for 'IEE612I' - if found, reconfigure console
KEY=(@y) * (@y=PA2)
KEY=(@y) * (@y=PA2)
ENDSEARCH * End of commands to perform if 'IEE612I' is found
*------------------------------------------------------------------------------* * If the IEE612I is still there, we want to delete the display area, if one is * * defined, because display areas cause problems for rules processing. * *------------------------------------------------------------------------------* SEARCH=(IEE612I) * Look for 'IEE612I' - if found, reconfigure console KEY=(k e,d@E) * Clear the display area (@E=ENTER) WAIT=1 * Wait 1 second for the command to be accepted
KEY=(@y) * (@y=PA2)
SEARCH=(IEE612I)
SEARCH=(IEE612I)
ENDSEARCH
ENDSEARCH
*------------------------------------------------------------------------------* * Search for error messages that the MCS console driver recognizes as * * bad modes and clear them. * *------------------------------------------------------------------------------* SEARCH=(IEE160I) * UNVIEWABLE MESSAGE KEY=(k e,d) WAIT=1 ENDSEARCH SEARCH=(IEE163I MODE= RD) KEY=(@y) WAIT=1 ENDSEARCH
SEARCH=(IEE163I MODE=) KEY=(@E) WAIT=1 ENDSEARCH SEARCH=(IEE164I) KEY=(@y) WAIT=1 ENDSEARCH
