You can use the following keywords in a script. See the Command and Keyword Reference Guide for keyword syntax.
Terminates the preceding SEARCH
Specifies what happens if a search fails
Sends a keystroke string to the target session
Searches the entire screen for a string of data
Causes the script to wait for the preceding keystroke string to be accepted by the system
Sends a single CA Automation Point operation instruction to a host session, regardless of whether the keyboard is locked
