CA Automation Pointprovides sample scan code files in the Distrib directory. The sample files (with .cod file name extensions) offer mappings for several types of terminals. Use your editor to modify these scan code files, if necessary, or to create new ones.
Note: User-created scan code files (with .cod as the file name extension) should be moved to the %AP_SITE%\MyFiles directory.
