The CA Automation Point keyboard configuration program can help you customize the keyboard parameter file. If the standard files do not exactly meet your needs, use the utility to redefine the appropriate keys.
To run the CA Automation Point keyboard configuration program
The program determines the value associated with the location of the key and displays that number on the first line. Both the current and default definitions for the key appear. For example, if you press the A key, the following output is produced:
Scan: 30 Current key definitions: KEY=SOH,SCAN=30(ctrl),map=(automate) KEY=A,scan=30(upper),map=(terminal,automate) KEY=a,SCAN=30(lower),map=(terminal,automate) KEY=ALT_A,SCAN=30(alt),map=(automate) Default key definitions: KEY=SOH,SCAN=30(ctrl),map=(automate) KEY=A,SCAN=30(upper),map=(terminal,automate) KEY=a,SCAN=30(lower),map=(terminal,automate) KEY=ALT_A,SCAN=30(alt),map=(automate) Current definitions are listed. Press key: K to keep, A to add, D to delete, M to modify, R to use defaults, Q to write file:
Option |
Explanation |
K |
Keep the current definition (if any). |
A |
Add a definition. |
D |
Delete all current definitions. The program asks you to confirm your selection. Answer Y to delete all current definitions. |
M |
Delete one or more definitions. The program displays the definitions one at a time and lets you keep or delete each definition. To change an incorrect definition, delete it and replace it with a correct one. |
R |
Replace the current definitions with the default definitions. Answer Y to replace the current definitions. |
Q |
Exit the program. |
After you select an option, answer any additional questions that the program asks.
Example 1:
The following example shows how to create a key definition.
Suppose you want to associate an IRPT instruction for your mainframe session with keystrokes CTRL+ALT+2. According to the previous key map table, the operation for an IRPT instruction is 3270_IRPT.
To create a key definition
Example 2:
The following table displays more sample key definitions and how they work:
Key Definition |
How it works |
KEY=a,SCAN=30(LOWER) |
Define key 30 as a lowercase a. |
KEY=A,SCAN=30(UPPER) |
Define key 30, shifted, as an uppercase a. |
KEY=SINGLE_QUOTE,SCAN=40(SHIFT) |
Define key 40, shifted, as a single quotation mark. |
KEY=PF1,SCAN=2(ALT), |
Define Alt+2 as PF1 on terminal emulator windows. |
KEY=QUIT,SCAN=61 |
Define key 61 as the Quit key. |
KEY=3270_IRPT,SCAN=2(CTRL,ALT), |
Define Ctrl+Alt+2 as a 3270_IRPT operation. |
