The following REXX programs run in automation sessions:
Invokes sign-on procedures to the AS/400 systems automatically when the AS400JMP REXX program finds that a sign-on procedure needs to be performed. You would not normally call AS400INI directly from your own REXX program.
Should be called from user-written REXX programs when a communications failure results in a nonzero return code from SESSCMDs.
Simplifies creating automatic actions to answer inquiry messages in the operator message queue.
Handles the sending of an OS/400 operator line command to one AS/400 system or to a group of AS/400 systems, which is enabled by the operator command facility.
