You can use all CA Automation Point rules keywords for AS/400 with these exceptions:
Using this keyword can cause unpredictable results. Instead of OSCMD, use the supplied REXX program AS400MRP to issue responses to messages, or write REXX programs to issue commands to the AS/400 MAIN menu command line.
Using this keyword can cause unpredictable results. Use REXX programs as detailed for OSCMD.
Instead of using SCRIPT, invoke scripts from REXX programs to ensure the integrity of communications with managed AS/400 systems.
For integrity reasons, use this keyword only in REXX programs.
