Symptom:
A high volume of messages occurs within CA Automation Point when CA NSM message monitoring is enabled. How can this volume be reduced?
Solution:
The Filtering Criteria button within the CA NSM Event Traffic Configuration dialog lets you restrict the set of messages to be processed by CA Automation Point. Only those messages containing the values specified for the listed filtering fields will be processed by CA Automation Point.
Note: If no value is specified for any field, CA Automation Point will process every message.
