Interacting with External Event Systems › Using the CA NSM Interface › Understanding the ADDRESS TNG Environment › The CA-AP NSM Gateway Service
For the ADDRESS TNG environment to operate between different machines, you must establish network connectivity to the machines that hold the CA NSM Repository or run Event Manager.
When you are ready to access the ADDRESS TNG environment from CA Automation Point, you must have an operating CA-AP NSM Gateway service on the machines running CA Automation Point.
To install the CA-AP NSM Gateway service
- Start Configuration Manager.
- Select Expert Interface, Automation, Events Interface, CA NSM WorldView Repository.
- Place a check mark in the box Enable the ADDRESS TNG Environment.
- Enter the information requested for the WorldView Repository, User Name, and Password fields.
- Click OK.
Copyright © 2012 CA.
