Previous Topic: Hardware Access Facility (HAF)
Next Topic: Monitoring HMC Messages with HAF
Configuring HAF
To configure HAF
  1. In Configuration Manager, navigate to Expert Interface, Automation, Events Interface, HAF Interface.
  2. Check mark the Enable Monitoring box.
  3. To the HMC list, add the community name and TCP/IP address for each HMC/SE workstation you wish HAF to monitor.
  4. Specify the path and filename of the HMC API DLL file (hwmwinca.dll), copied to the local CA Automation Point server.
  5. Click OK.
    Your settings are saved.
  6. Restart CA Automation Point to activate HAF.
