Using Program-to-Program Queues › Configuring PPQs › PPQSTAT.bat Program
PPQSTAT.bat Program
Run the PPQSTAT.bat program (located in the installDir\BIN directory) to display the status of CA Automation Point PPQs. You can use PPQSTAT.bat to verify successful installation or to monitor the status of PPQ network transports. PPQSTAT.bat displays the following:
- Queues on the local machine
- Queues from the remote workstations that are accessed by REXX programs on the local workstation
- The current state of all Configured Network Transports
- The current state of each TCP/IP connection listed under TCP/IP Host Names in the Program-to-Program Queue dialog
Copyright © 2012 CA.
