The following illustration shows the flexibility that CA Automation Point provides for accessing variables:
You can use the CA Automation Point SET rules keyword and CA Automation Point command processors to control CA Automation Point status variables. However, the global variable environment gives REXX programs global access to all variables in the variable pool.
See the Command and Keyword Reference Guide for more information on the SET rules keyword and CA Automation Point Command Processors.
