The REXX programming language, with its standard set of built-in functions, allows you to migrate your REXX programs between implementations. For example, you can migrate REXX programs between CA Automation Point and CA OPS/MVS.
When designing REXX programs for portability, keep the following points in mind:
Note: Command processors under different platforms may have additional platform-specific parameters and unique return codes.
REXX provides functions for determining the current host environment so that a REXX program designed for portability can trap environment-specific commands. For more information, see the section How Do CA Automation Point and REXX Communicate? in this chapter .
For example, the "¬=" (not equal) operator works only on an EBCDIC platform; however, "<>" (also a not equal operator) is valid on both ASCII and EBCDIC platforms.
