The Web MV Action Messages and Normal Messages tables each allow you to view up to 500 messages from the CA Automation Point server at any given time. However, you can scroll back or forward to view previous or newer messages in each table, using the scroll bar on the right side of the table:
To view previous messages, do one of the following:
A previous message request is automatically generated and the previous 100 messages are added to the top of the table.
To view newer messages, do one of the following:
A newer message request is automatically generated and the next 100 messages are added to the bottom of the table.
Note: This is only necessary if the table is not in Auto End mode. If the table is in Auto End mode, it will automatically scroll to the latest message received from the CA Automation Point server.
