To start a REXX program or a script in a session managed by CA Automation Point
Important! CA Automation Point uses the three-character file name extension to determine whether a REXX program or a script should execute. Follow this convention when naming your REXX programs and scripts:
When you enter the REXX program or script file name in the command area, supplying the extension is optional. If you specify a file name without an extension, CA Automation Point searches first for a REXX program, and then for a script with that file name.
