CA Automation Point supports message processing for the asynchronous console types shown in the following table.
Note: These terms are not industry-standard console names. Rather, they refer to the Console Type setting for the session, which designates how CA Automation Point should process the data on the screen.
Asynchronous Console Type |
Description |
ASYNCH |
Generates messages matching the ASYNCH message criteria |
TANDEM |
Generates messages matching the EMS format |
TANDEMALL |
Generates EMS messages, but passes text not matching the EMS format for processing through rules as an ASYNCH message |
VAX |
Generates messages that match the OpenVMS OPCOM message criteria |
VAXALL |
Generates OpenVMS OPCOM messages, but passes text not matching the OPCOM format for processing through rules as an ASYNCH message |
DTX |
When attached to the DataFrame environmental monitoring product, this console type parses the special message format used by DataFrame and creates standard CA Automation Point messages |
