Configuring CA Automation Point › Managing Your Site Configuration › Export and Import Operations › Manage Site Files Using Configuration Manager
To manage your site files from Configuration Manager, choose Manage Site Files from the File menu.
The Manage Site Files dialog appears, displaying the current active site directory and a list of standby site directories that are not currently in use, including ones that were previously exported. You can use this dialog to perform the following actions:
- Select from or sort the list of standby directories.
- Make a backup copy of the active site configuration.
- Switch to a standby site configuration. This automatically backs up the current site configuration to a fixed archive named "Site_autobackup," then extracts the former standby site archive into the active site directory.
- Delete a standby site archive.
For more information about this dialog, see the dialog Help.
Copyright © 2012 CA.
