Previous Topic: Voice Processing CommandsNext Topic: VOX Commands that Perform I/O Operations
Utility Commands
The following commands are ADDRESS VOX utility commands.
GETTAPIDEVICELIST
Lists all the TAPI devices that are installed under Windows.
SETENGINE
Allows you to modify notification server settings.
SETMSGSTREAM
Duplicates the message stream from CA Automation Point to another queue that is accessible through PPQs, local or remote.
SETTRACE
Start and stop trace logging.
SLEEP
Causes the issuing REXX EXEC to enter a system sleep state.
STARTREXX
Starts another REXX program.
VER
Provides the version number and configuration information of the CA Automation Point notification services at your site
