Previous Topic: Specifying Table Columns for Your MessagesNext Topic: Message Color Mapping
Specifying the Color of Your Messages
Web MV allows you to specify or change the colors of your messages. This feature can be helpful to you for message organization, viewing, and so on, particularly if you are viewing a large volume of messages.
To specify or change the background color of your messages.
  1. From the Options menu on the Web MV main window, select Colors.
  2. Select Table Colors.
    The Table Color Selection dialog displays.
  3. Select the Table Background from the Color Properties drop-down list for the desired message type.
  4. Click the corresponding Change button.
    The specified Background Color Selection dialog displays.
  5. Select a new color for this field, then click OK.
For more information about the fields in the Table Color Selection dialog, see the Web Message Viewer HTML Help.
