Viewing Remote Sessions › Web Message Viewer › Enabling Web MV › Web MV Dialog
Web MV Dialog
The areas of the Web Message Viewer dialog are as follows:
- The Message Database Settings area allows you to specify the maximum number of messages to keep in the database. You can only view as many messages as you specify in this setting.
- For example, specifying keeping 10,000 messages and then viewing message 10,001, Web MV overlays message 1 with message 10,001. In this scenario, Web MV keeps overlaying messages, only allowing you to view the last 10,000 messages at a time.
You can specify a maximum of 10000000 messages. We recommend that you allocate a minimum of at least 20,000 messages.
Important!
- The database resides in the directory %AP_DATA%\Temp. This directory is created on the hard drive on which CA Automation Point is installed.
- Web MV deletes the existing database before creating a database with an updated message capacity.
- Web MV deletes the existing message database when Web Message Viewer is disabled, but saves the user profile settings for future use. These user profile settings are used when you next activate the Web Message Viewer.
- The Enable Windows for Web Viewing area of the dialog allows you to specify which CA Automation Point-managed sessions are eligible for Web Message viewing. Because these sessions are not defined in the session definition set, these check boxes provide the same functionality as the Enable Web MV field for user-defined sessions. To view messages from these sessions, select the appropriate session name in the Web Message Viewer application. The following session names are assigned to these CA Automation Point-managed sessions: AXC (AP Msg Recall), OPS (CA OPS/MVS) Messages, and VOX (AP Notification Messages).
- The Advanced button displays the Advanced dialog, which allows you to further configure Web MV.
For information on the Advanced dialog, see the Configuration Manager help.
- The Security button displays Remote Security dialog, which allows you to configure the security for Web MV.
For information on the Remote Security dialog, see the Configuration Manager help.
