You are not required to run any CA software on your remote client computer. You can program HTTP requests directly from many different programming languages. However, when utilizing the CA Automation Point RequestService Java API or command-line application, deploy CA software on your remote client computer. The RequestService client can be used on Windows, Linux, or z/OS computers. For more information, see the CA Automation Point Installation Guide for supported operating systems.
Install a Java Runtime Environment (JRE) from http://www.java.com on your remote client computer before you run the RequestService client. JRE version requirements are described in Software Requirements section of CA Automation Point Installation Guide.
To deploy the RequestService client to your remote client computer:
%AP_HOME%\Sample\websvc\RequestServiceClientDist.zip
For the z/OS (USS) distribution, copy the following file instead:
%AP_HOME%\Sample\websvc\RequestServiceClientDist-USS.tar
Client documentation and samples are also included in the client distribution.
